Old 03-07-11, 01:53 PM   #11
muzikill
muzikill's Avatar
Default Re: sv fuel running costs.
yup just one of those times you top it up on the passing. Another thing when i cleaned out the tank i couldnt believe how much fuel i took to get it above reserve. does anyone know the amount the tank still has when the rserve light comes on and what mileage to expect extra?
Old 03-07-11, 02:33 PM   #12
barwel1992
£9.97 for 65miles at £1.33 a littre
so about £1.50 a mile
Old 03-07-11, 03:08 PM   #13
muzikill
muzikill's Avatar
calculate it again mate.....1 50 a mile id be wondering where the problem was !
Old 03-07-11, 03:34 PM   #14
Teejayexc
£1.50/mile , equates too £97.50 for 65 miles you twonk
Old 03-07-11, 07:18 PM   #15
barwel1992
LOL
15p a mile wasn't concentrating
Old 03-07-11, 07:32 PM   #16
Anthropomorphic
That's good to hear, all these folks saying 10p a mile make me wonder if I'm riding it wrong as I am closer to 15p than 10p.
Old 03-07-11, 08:47 PM   #17
barwel1992
ride flat out buy any chance ?
Old 04-07-11, 11:01 AM   #18
maxinc
I average 10-11p / mile when riding progressively within legal speed limits +/- 10 mph
Old 04-07-11, 11:05 AM   #19
daveyrach
Fuelly.com tells me 1 mile on my SV costs 16.8p
Old 04-07-11, 01:23 PM   #20
Stonesie
Fuelly tells me mine is 9.8p/mile and averaging over 60 mpg, big rideouts help as the speeds usually drop and doing 200 miles with only one cold start also helps... Commuting drops it down to about 50mpg as theres lots of hills on my route, and plenty of B roads. It is quicker to go by car because I never go the direct route on the bike.
carb fuel/running problem dazzaboy Bikes - Talk & Issues 6 09-08-10 05:47 PM
running problem - as if running out of petrol Nick8529 SV Talk, Tuning & Tweaking 20 27-10-09 11:47 AM
Fuel light = rough running? arcdef SV Talk, Tuning & Tweaking 16 26-08-09 12:52 PM
Running out of fuel. the_lone_wolf Bikes - Talk & Issues 17 24-12-08 10:06 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
