#41 |
I think the original issue of speedo accuracy was more centered around the deliberate adjust up in speed of the readings as imposed (indirectly) by law, which there is general agreement on. I think we got a little sidetracked with details
![]() BTW I still need to find out if distance recorded by the odometer is 9/10% higher than actual just like the speedo...if it is that's just plain wrong... different bikes with varying accuracies would record varying falsely inflated mileage...a speedohealer at £60(?) might be worth it if that's the case...
Mark Triumph and Suzuki owner Last edited by kaivalagi; 10-03-11 at 10:05 PM. |
#42 | ||
#43 | |
#44 | |
Now thats an interesting point. |
#45 | |
Today looks to be a nice day, if I finish work early enough I'll go on a little bimble for half an hour with my tracks running and hopefully have something to go on....even if not very accurate we should see a distance at one end or the other of the accuracy scale ![]()
Mark Triumph and Suzuki owner |
#46 |
I went out for a ride and although overcast and not great for my crappy gps on my phone I got the results as follows:
Odometer: 37.8 miles GPS on Android via My Tracks: 36.83 miles That's around 2% difference which makes me believe that the odometer is not inflated by 9/10% like the speedo is....Also the GPS is most likely reading low because of lost signals around bends etc that would give straight line distances where this is not the case...see the image below, where there is no blue the signal was lost... ![]() I will give this another go when the weather is better, like I say it was overcast today, I nearly didn't bother as I didn't get a gps fix from home, I tried again once I'd travelled for a bit Anyway I think this raises another question, for all those that have fitted speedohealers are the odometer readings on their bikes lower than they should be because of the reduced speeds on the clock !!!??? ![]()
Mark Triumph and Suzuki owner Last edited by kaivalagi; 11-03-11 at 05:33 PM. |
#47 | |
Sounds like a good next step to me. Another one to try and increase the accuracy might be a long straight line and back. That should avoid some of the signal loss errors. |
#48 |
I'm not sure if an inaccurate odometer would matter anyway. All of the odo's on all of the bikes would be out by approximately the same amount if that were the case. Even if it one odo was accurate, and another was 10% out, you are not going to look at two bikes in autotrader, one with 30,000 and one with 33,000, and choose between them based upon mileage. You could say you would save 10% on your servicing costs, but even at main dealer prices, that's £20 every 4000 miles, and it's not a bad thing if your bike gets serviced more regularly than the schedule anyway.
#49 |
Very true, I was getting carried away with the detail, I now know that the odometer is accurate where as the speedo id inflated...that's a nagging question put to bed anyway
![]() Atleast if there is a discrepancy it's the right side of actual to help not hinder when it comes to servicing...
How accurate should you be when adjusting the chain? | cringer | SV Talk, Tuning & Tweaking | 5 | 15-06-10 03:25 PM |
Is GPS MPH accurate | hindle8907 | Bikes - Talk & Issues | 60 | 12-08-09 08:16 AM |
Speedo accuracy. If your '99 650 is showing 37mph on the speedo. | lloyd_christmas | SV Talk, Tuning & Tweaking | 14 | 12-06-08 12:02 PM |
Google Maps. How accurate? | petevtwin650 | Idle Banter | 1 | 17-03-08 12:45 PM |
Most consistently accurate weather site.... | rob13 | Idle Banter | 16 | 20-08-07 12:20 PM |
