Old 05-04-11, 10:26 PM   #1
SVforvictory
Default Fitting Exhaust Gaskets
What is the best way to fit exhaust gaskets? (The steel wool-type ones that fit in the cylinder heads). I've got a '00 curvy and the gaskets seem bigger than the ports...
Old 06-04-11, 06:05 AM   #2
Spanner Man
Default Re: Fitting Exhaust Gaskets
Good morning.
Some pattern gaskets are somewhat oversize, but providing you have original gaskets the problem is most likely a little corrosion on the side of the ports themselves. You'll have to scrape it off.
Stick the new gaskets into place using a little instant gasket. This will help prevent dislodging them when fitting the exhaust.
Cheers.
Spanner Man
Old 06-04-11, 09:11 PM   #3
fastdruid
fastdruid's Avatar
The alternative to instant gasket is grease.
Druid
Old 06-04-11, 09:16 PM   #4
Steel wool? In cylinder head? Pretty sure they are little silver/brass things in head, the long steel wool things go in the downpipe
Old 06-04-11, 09:43 PM   #5
fastdruid
fastdruid's Avatar
Nah, from memory the OEM head gaskets look like a highly compressed brillo pad and cost a fortune[1].
Other makes seem to either use a crushable copper ring or a fabric looking ring (probably ceramic fibre) with a steel inner and outer.
Druid
[1] £5 each IIRC.
Old 10-04-11, 08:47 PM   #6
SVforvictory
Thanks guys, after lots of scraping it fitted perfectly. I think some sealant had been used previously and the "crust" that was left was blocking the new gasket.
Fitting Exhaust Gaskets? loganpip SV Talk, Tuning & Tweaking 15 26-01-11 05:30 PM
Fitting new cylinder head cover gaskets flymo SV Talk, Tuning & Tweaking 12 05-10-10 08:48 AM
Exhaust gaskets mikerj SV Talk, Tuning & Tweaking 2 26-08-10 10:07 AM
SV1000 exhaust gaskets Mark_h SV Talk, Tuning & Tweaking 3 12-03-08 09:24 PM
Fitting exhaust gaskets andyaikido SV Talk, Tuning & Tweaking 4 19-02-06 05:29 PM
