Old 23-01-11, 11:37 AM   #1
loganpip
Default Fitting Exhaust Gaskets?
Hi Could anyone tell me how to put new gaskets on my sv650 exhaust... the front one looks easy but how do i get to the back one? what to take off to get to it ? PLEASE HELP...
Old 23-01-11, 12:29 PM   #2
Default Re: Fitting Exhaust Gaskets!!!
Don't think I changed mine when I swapped the headers over, because I didn't remove the stubby connector pipe. The rear header clamps to a a stubby connector pipe to the exhaust port.
If you haven't taken it off, then it should be fine, otherwise its a pig of a job.
So if it ain't broke then don't fix it.
Old 23-01-11, 12:42 PM   #3
barwel1992
need to do my front as its leaking bodged at the moment with fire gum lol
Old 23-01-11, 12:44 PM   #4
squirrel_hunter
squirrel_hunter's Avatar
As Maviczap said if you haven't removed the rear stub then you don't need one. However if you have...
On my Curvy I had the tank off and moved the rear coil off of its mounting so I could get to the bolts better with a ratchet spanner. Just make sure the stub is seated properly in the recess before tightening it up. As a little note the clamp on the pipe joint was quite corroded on mine and I had to cut it off to remove it. I then tidyed it up by grinding it off at the weld and used stainless exhaust clamps to replace them. I also use a little grease when putting the new gasket in to help hold it in place while moving the exhaust about.
I would imagine the principle would be the same for a Pointy but I've not changed the exhaust on one of these yet.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 23-01-11, 12:49 PM   #5
barwel1992
how do you get the old ones out mine stuck quite firmly in there lol
Old 23-01-11, 04:21 PM   #6
I just dig mine out with a thin screwdriver and a couple of gentle taps with a small hammer under the edge of the gasket
Old 23-01-11, 04:24 PM   #7
barwel1992
ok cheers will order a new one this week
Old 24-01-11, 09:03 AM   #8
STRAMASHER
STRAMASHER's Avatar
... As a little note the clamp on the pipe joint was quite corroded on mine and I had to cut it off to remove it. I then tidyed it up by grinding it off at the weld and used stainless exhaust clamps to replace them. I also use a little grease when putting the new gasket in to help hold it in place while moving the exhaust about.
My K3 is blowing at the gasket/clamp between the pipe and "stub". Audible phut-phut but not the kind of noise you get from a proper hole.
Is this an MOT fail? Or is it an "advisory" and at the testers descretion?
Old 24-01-11, 10:12 AM   #9
loganpip
Default Re: Fitting Exhaust Gaskets?
Wow thanks guys... A real help and i will post my results to tell you how i got on..
Old 24-01-11, 11:29 AM   #10
loganpip
Well i have to say that was pretty easy... Just the front gasket was blowing making it backfire everytime i let gog of the throttle... Undid the 2 front bolts and got just enough play to scrape out the old bits of gasket(O ring) and clean it up with a screwdriver and wire brush... placed the new one in place with the aid of a bit of grease and tightened up the bolts... Turned it over and she sounds great now... Oh and had to take her for a spin too
Fitting new cylinder head cover gaskets flymo SV Talk, Tuning & Tweaking 12 05-10-10 08:48 AM
Exhaust gaskets mikerj SV Talk, Tuning & Tweaking 2 26-08-10 10:07 AM
SV1000s k4 Exhaust gaskets asteer17 SV Talk, Tuning & Tweaking 10 13-07-10 04:05 PM
SV1000 exhaust gaskets Mark_h SV Talk, Tuning & Tweaking 3 12-03-08 09:24 PM
Fitting exhaust gaskets andyaikido SV Talk, Tuning & Tweaking 4 19-02-06 05:29 PM
