Old 01-11-11, 06:17 PM   #1
Fraser24
Default Oil pump drive
I need a bit of advice , I pulled off my clutch cover to fit WEMOTO heavy duty clutch springs and found my oil pump drive damaged, about 3rd of teeth have the tops missing, I think I've correctly identified a new item 16331-19FOO but the parts fiche shows the sequence of assembly different to how I removed it. The fiche shows- shim, gear, drive cross piece and then the circlip, can anyone confirm that this is correct and has anyone got a spare drive gear cuz it's about 2 weeks to get a new one, thanks, Fraser
Old 02-11-11, 03:13 PM   #2
Default Re: Oil pump drive
I have one from curvy.
Not 100% on order of parts. Makes sense that shim would be on oil pump side as epr fiche.
Old 02-11-11, 05:00 PM   #3
Fraser24
Thanks, I've managed to find and buy one on fleebay, I guess I will try both reassembly procedures and see what works best from an engineering point of view, Fraser
Old 02-11-11, 05:23 PM   #4
squirrel_hunter
squirrel_hunter's Avatar
This is the correct order. Although you will need to put the drive cross piece in before the gear. I've just taken mine apart and this is the order it will go back in.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 03-11-11, 02:18 AM   #5
zadar
Shim is between gear and pump. You can buy steel gear from 99 model bike.
Old 06-11-11, 05:32 PM   #6
Fraser24
Thanks for all your help, it's back together and running fine, Fraser
Curvy SV Water Pump Drive? Elltg Bikes - Talk & Issues 8 13-11-10 05:57 PM
Acceletrator pump SUPERSTARDJ01 Bikes - Talk & Issues 11 08-12-09 12:36 PM
Fuel pump cornishrider SV Talk, Tuning & Tweaking 6 02-03-08 07:25 PM
K5> fuel pump phil24_7 Stuff Wanted 11 29-10-07 05:18 AM
Tyre pump rpwoodman Bikes - Talk & Issues 22 24-10-06 01:49 PM
