Hey guys, im going to upgrade my chain and sprocket in a couple weeks and i figured i may aswell upgrade my rear shock an possible my front ones? just wondering which is best for a 16/17stone guy (i know! feel sorry for the bike huh?!) which wouldnt require too much modification (none if thats possible
![]() as always if this has been covered please point me to where i can get the info? many thanks guys jason |
A 2006/07 zx10r shock, they fit perfect, just need to remove heat shield from tool box
#4 | |
For the rear Ohlins will do you one for around £650, or a GSXR1000 standard unit can be found on eBay for under £100. The question really should be what rear shock can be recommended for the budget of £XXX?
The same for the front, an Ohlins WSBK Spec set of forks is around £10,000 the last time I looked, a GSXR swap can be around the £800 - £1000 mark, or a litre of 15w oil is about £10. Oh and are you looking to do this yourself or not as labor cost the last time I took a bike in to a garage is c.£50 p/h? |
#6 | |
http://www.ebay.co.uk/itm/KAWASAKI-Z...#ht_500wt_1054 |
#7 | |
As for doing it yourself, its not actually that bad to do if you have a good set of tools and some equipment to raise the rear like an Abba Stand. |
#8 | |
#9 | |
I'd choose something with a stiffer spring such as a 2008 zx10r shock. Has a spring rate of 9.1 kg/mm and will suit much better. Admitidly it'll be a little more of a faff to fit but once in I reckon it'd perform better. See link https://docs.google.com/spreadsheet/...COvG24gH#gid=1 Up front some K tech .95 springs and fresh oil will do the job nicely and will come in at around £100. Debrix emulators are another £40 or so quid and will again improve the front end. YC is your man for this! |
#10 | |
pointy replacement shock | Kilted Ginger | SV Talk, Tuning & Tweaking | 2 | 16-04-09 09:43 AM |
Shock spring replacement... | Gnome | SV Talk, Tuning & Tweaking | 5 | 30-06-07 05:55 PM |
Replacement Rear Shock (again!) | Luckypants | SV Talk, Tuning & Tweaking | 21 | 17-09-06 11:54 PM |
replacement rear shock? | m6rk | SV Talk, Tuning & Tweaking | 15 | 06-04-06 12:41 PM |
rear shock replacement? | cassius | SV Talk, Tuning & Tweaking | 8 | 13-04-05 09:43 PM |
