Old 24-08-12, 03:49 PM   #1
JonGeorge
Default Does SV have gearbox oil?
Does my curvy 99 have separate gear box oil?
Old 24-08-12, 03:49 PM   #2
Sv650jamie
Default Re: Gearbox Oil
Nope uses engine oil to lube the gears!
Old 24-08-12, 03:53 PM   #3
JonGeorge
Ahhh, I put 10/40 semi synth in my bike on Saturday.... help?
Old 24-08-12, 03:54 PM   #4
JonGeorge
1.5 litres roughly.
Old 24-08-12, 04:01 PM   #5
jambo
jambo's Avatar
Back up...
1) Did you do this on a whim, or had you checked the oil level, on a flat, level surface with the engine off, and found the level in the sight glass was low enough to need 1.5L to bring it up to between low and high levels?
2) Did you use 10w/40 semi synth motorcycle engine oil or gearbox oil?
Jambo
Old 24-08-12, 04:35 PM   #6
Originally Posted by JonGeorge View Post
1.5 litres roughly.
No, 2.3 litres of semi synthetic
Old 24-08-12, 08:03 PM   #7
JonGeorge
Hi. It was on a flat all night. There was no oil in the sight glass and it took 1.5 litres of 10/40 semi.synth car oil
Old 24-08-12, 08:20 PM   #8
Biker Biggles
Biker Biggles's Avatar
Better the wrong oil than no oil.
Old 24-08-12, 09:27 PM   #9
squirrel_hunter
squirrel_hunter's Avatar
Did you hold the bike up level when you checked or was this with the bike on the side stand?
If you use car oil, my understanding is the clutch will not like it.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 25-08-12, 07:18 AM   #10
Yep, not good for the clutch at all
98-02 gearbox ok for k3? muzikill SV Talk, Tuning & Tweaking 2 15-01-11 10:38 AM
K3 gearbox muzikill Stuff Wanted 0 12-08-10 08:34 PM
Gearbox Richie Stuff Wanted 0 09-07-07 08:09 PM
Gearbox Fix? seandixie SV Talk, Tuning & Tweaking 11 29-06-07 09:32 AM
Gearbox Daglad SV Talk, Tuning & Tweaking 12 02-04-06 09:26 PM
