Old 20-02-14, 09:46 PM   #1
Jayneflakes
Jayneflakes's Avatar
Talking As a purely hypothetical question about frames - Pointy/Curvy swap?
I have been chatting to the wife and she thinks that I am mad for even considering this, but I have had an idea. As some of you may know I wanted to chuck some money into my bike and make it a little bit more special to me.
The plan is to sort the front end and get a new rear shock. However while perusing E-Bay for Gixxer front ends, I found a Curvy main frame with no sub frame or swing arm going for £25. I really like Curvy frames and with that thought came the ultimate heresy. Could I strip my pointy all the way down to its constituent parts and rebuild it with a Curvy frame, fitting my sub frame, tank, swing arm and plastics with out having to do any major alterations?
The wife says I should not bother because the pointy frame is prettier and it will require me learning a new number plate.
So what are your views then Folks?
Jayne you're a Pussy Magnet
Old 20-02-14, 09:54 PM   #2
Default As a purely hypothetical question about frames
A lot will fit, a lot won't - it isn't a straight bolt up job.
Old 20-02-14, 09:56 PM   #3
squirrel_hunter
squirrel_hunter's Avatar
Default Re: As a purely hypothetical question about frames
You would then no longer have a pointy and would not be able to have the number plate. However others have fitted some of the pointy plastics, but not sure of the tank. Either way it is a lot of hard work.
And you are correct, the curvy frame is the best looking.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 20-02-14, 10:05 PM   #4
TamSV
TamSV's Avatar
Nudist did that. I'm sure there was a build thread on SV Rider.
He made a lovely job of that bike, but he didn't do it in an afternoon.
Old 21-02-14, 08:13 AM   #5
shiftin_gear98
shiftin_gear98's Avatar
Default Re: As a purely hypothetical question about frames - Pointy/Curvy swap?
TamSV, thanks for sharing, that is one pretty bike. But a lot of work.
Currently driving a Corsa....
Old 21-02-14, 01:44 PM   #6
MJC-DEV
MJC-DEV's Avatar
It seems to me that you are secretly yearning for a different bike - time for a change maybe?
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 22-02-14, 03:40 AM   #7
Jayneflakes
No, but I would love to make my bike unique to me, I love building things and am something of a tinkerer.
If only Motorbikes were as easy to build as Technic Lego!
The Hypothetical Situation DJ123 Idle Banter 24 25-10-12 07:50 AM
Hypothetical situation... Stig Idle Banter 24 19-04-10 06:33 PM
Hypothetical Dinner Party Guests fizzwheel Idle Banter 74 19-10-07 12:54 PM
Hypothetical question re ill health and benefits timwilky Idle Banter 5 29-12-06 05:40 PM
Hypothetical Crash Yellow650 Bikes - Talk & Issues 20 06-07-06 10:14 AM
