got sv650 t teg petrol tank breather & overflow pipe got a fracture in side the tank do anyone no where or who can repair tanks to fit new pipe as can not find no one out there do it i did get second hand one but wrong colour so if can get repaired save bit i hope lol
If I'm understanding you correctly the petrol tank filler neck drain pipe that runs through the tank itself to the drain point at the back has rusted through?
Commiserations, as it's not uncommon, especially if the drain pipe gets blocked and water gets trapped in there. Fixing this is not straight forward, I've seen a few fixes done in the past but none were permanent fixes which I think would require opening the tank which is pretty major surgery. What colour tank were you after? Do you know exactly where the pipe has rusted through? Jambo
John T
Can't help with repair. Maybe worth looking in the classified as in MCN?
It's worth commenting to others that this pipe is prone to rust and therefore fail. I used to spray WD40 down mine to try and rust proof it. I've been doing the same on my VFR. PS. I also sprayed the underside of my curvy tank as that started turning a nice shade of brown early on. sent via Pony Express
Thanks for the top tip, will do that on mine tonight.
Its light blue not dark blue
Sent from my Nexus 7 using Tapatalk |
I may know someone with a (hopefully) rust free tank in that colour, PM me if you would like to be put in touch.
Jambo
What's price you no plz as I hoping send this one back to lad of eBay if can so don't lose out big time
#9 |
i would just like to mention that if there is rust already in the breather metal spigots then WD40 will do nothing to cure it. you need phosphoric acid to cure rust on metal. if you treat the metal parts with FA first then it will kill any rust already there after which you can then use a preventative like WD40 or ACF-50.
the milky white stuff they sell in halfords under the name 'kurust' is good, do not get the gel. give it a few applications to make sure. |
#10 |
John T
Good tip Bibio. I think its best to assume that rust is present.
Would you block the tube first before applying the treatment or leave for a bit or just pour it through a few times? sent via Pony Express
Admin for this forum and the main site. John@sv650.org Last edited by admin; 04-06-14 at 01:21 PM. |
Fuel pouring from carb breather pipe | miniracertim | Bikes - Talk & Issues | 2 | 01-09-10 12:09 PM |
oil catch tank / oil breather help. | Nicky S | SV Talk, Tuning & Tweaking | 10 | 13-01-09 01:13 AM |
fuel tank breather | mikey devon | SV Talk, Tuning & Tweaking | 7 | 11-10-08 12:53 PM |
Breather pipe? | Scubini | SV Talk, Tuning & Tweaking | 6 | 15-02-07 10:43 AM |
fuel tank breather | timwilky | SV Talk, Tuning & Tweaking | 4 | 22-01-06 09:06 PM |
