Old 30-06-14, 10:15 AM   #1
reidy
Default Rusted exhaust nuts - Dremel?
Hi all, i have an issue most people probably have had with rusted exhaust bolts where it meets the engine block, i want to get them off but im not sure how, both rusty and rounded ive read various things regarding this about heating the nut etc .... i was thinking why cant i just use a dremel and carefully cut the nut in half ? Sure after one cut i could prise it appart, there rusted anyway, one of them was a 12mm now is like a 10.5mm with it corroded like that surely it should give up fairly easily ?
Any thoughts appreciated
Old 30-06-14, 10:49 AM   #2
TamSV
TamSV's Avatar
Default rusted exhaust manifold bolts ....., dremel ?
Yep. I drilled mine off, but much the same idea. They looked like twiglets so i didn't bother trying any non destructive methods.
Old 30-06-14, 11:21 AM   #3
jambo
jambo's Avatar
Default Re: Rusted exhaust nuts - Dremel?
I have used a junior hacksaw for this, running down the length of the nut on one side, *just* touching the threads. When you have exposed the tip of the threads all the way down, give the cut faces of the nut a sharp tap with a drift and hammer and it should split on the now very wasted section, opening up slightly. You can then generally spin it off. No fuss, no snapped studs.
Having been shown this method by Mr Squid, I don't even bother with anything else unless they look in great condition. The pain of dealing with snapped studs is just not worth it.
Jambo
Old 30-06-14, 01:23 PM   #4
I used a dab of C4
Old 30-06-14, 01:50 PM   #5
keith_d
keith_d's Avatar
I used a dab of C4
A whole lot safer than that stuff the Americans supplied to the bike shop in Nagasaki.
I'll admit that a single application did get the nuts off the studs, but it vaporised the rest of the bike.
Old 30-06-14, 08:12 PM   #6
squirrel_hunter
squirrel_hunter's Avatar
I've taken them off with Irwin sockets before. Replace the stud and the nut at the same time. After cutting the nut off there is likely to be damage to the stud anyway so its going to be stud extractors after if required.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 30-06-14, 09:48 PM   #7
jambo
jambo's Avatar
If you're careful the damage to the stud is a slight flattening of one face. Plenty of purchase left for the new nut.
Jambo
Sent without a real keyboard
Old 30-06-14, 10:13 PM   #8
reidy
Thanks all for the comments, will have a go at doing it on my next day off work
Rusted tank - Curvy. chrissy1975 SV Talk, Tuning & Tweaking 16 06-06-14 06:20 PM
Curvy tank drain tube rusted. fchat63 SV Talk, Tuning & Tweaking 11 19-01-14 10:43 PM
What dremel DarrenSV650S Bikes - Talk & Issues 0 28-03-10 10:39 PM
Solution for rusted bolts? suzsv650 Bikes - Talk & Issues 44 19-03-09 10:17 PM
SV650s K2 Exhaust stuck rusted on! any advice? alien19779 SV Talk, Tuning & Tweaking 3 06-03-06 12:39 AM
