#21 | |
Always been just short of 4l in mine (IIRC, the engine is stamped 3.5l, then there's the filter to take into account). EDIT: Just been out to the bike, it's stamped with 2300ml, but it's always been more than 3l, and not far off 4l (though never measured it) to do an oil/filter change. |
#22 |
Needs more than 2.3. Curvy takes that without filter change. Pointy also has oil cooler to refill.
I suggest you are just checking it wrong or have filled past the window (with the fresh anyway) Before changing it did you try tilt the bike towards you etc?
#23 |
Took it up to 2.5 ltrs and lent it right over and the oil is just showing!
Took it up to just over 3ltrs and its bang on. The engine is even stamped 2.3 ltrs and chap 2.14 "Oil change" in the manual definitely said 2.3 ltrs....................however in chap 2.15 "Oil filter change" it says 2.7 ltrs.....but that is still nowhere near the 3.1 ltrs that mine holds.....gggrrrhhhh Loads of heartache because of incorrect data. Thanks for your input gang |
#24 |
It may need another topup after being run and the oil galleries and cooler have been filled.
#25 | |
I have really never quite understood how they can say 2.3L!!! |
#26 | |
#27 |
As YC alluded to, 2.3l is the engine case capacity (minimum I suspect), then there's the oil filter & oil cooler (on a pointy only) to fill. The oil cooler itself probably takes somewhere around half a litre, possibly more.
#28 |
Well at least OP knows 3 litres of a can has to go.
#29 | |
As for your engine, if your down a ltr you may be lucky. Depends on how long it been like that. I used to run one of my old engines like that and it lasted quite a while (relatively speaking). |
Plenty of 02 curvy bits left for sale | mjf65 | For Sale - SV's and SV related items | 8 | 16-11-08 07:19 PM |
sv650's are plenty enough for road use but still want a 1000...possibly sv1000 | riktherider | Bikes - Talk & Issues | 29 | 20-07-07 06:52 PM |
Plenty of Winter gear, not much summer? | Pinhead | Bikes - Talk & Issues | 8 | 20-07-06 03:40 AM |
anyone wanna swap my hi level leo vine for a low level one | spakmitten | Exhausts | 1 | 16-06-06 08:59 AM |
Plenty of notice | Dicky Ticker | The Essex Lounge | 11 | 05-06-06 05:31 PM |
