Old 01-02-11, 06:27 PM   #21
Default Re: New end can and K&N filter - fuelling changes?
Originally Posted by johnnyrod View Post
I stand corrected about the lambda sensor. I'd whack the can on and try it, the Fi should adjust itself to suit, it won't be a long way off stock so should manage it. if it runs like a bag of spanners you'll know soon enough.
How do you know what part of map lambda adjusts?
Who says it adjusts any part of on throttle map and not just steady state cruise and/or tickover?
Old 01-02-11, 06:28 PM   #22
Originally Posted by SUPERSTARDJ01 View Post
I stuck an end can on my old SV and it ran ok, but with the ZX I had it dyno'd scary when they're doing it to see your pride revved that hard and be that load, but would recommend.
Too right, mine sounds bloody ace at full chat! And with the other system it was shooting flames near a foot long on the rev limiter and overrun
Old 01-02-11, 09:17 PM   #23
Scareysurfer
Hopefully this is the link to the quick video of it:
http://www.youtube.com/watch?v=2bu4haOE0y0
Not sure if the link will work but fingers crossed.
Scarey
Old 03-02-11, 12:39 PM   #24
johnnyrod
johnnyrod's Avatar
I don't but I'd still give it a try. It'll adjust more than nothing at all and I wouldn't expect it to run so lean that it'll explode.
Old 03-02-11, 01:40 PM   #25
SV650Racer
Non of the Suzukis run a closed loop lambda system like cars so they wont self adjust.
TBH every bike even stock would benefit from a remap as the maps downloaded into the ecu from the factory are just generic. As engines run in and as no two injectors will flow exactly the same gains can be had.
Always worth sticking it onto a dyno for an air fuel run to check at least.
Altering FI fuelling? TheGreyWolf SV Talk, Tuning & Tweaking 2 05-05-10 11:10 PM
Fuelling problem? Toriiii33 Bikes - Talk & Issues 9 09-06-09 09:12 PM
fuelling up stanie SV Talk, Tuning & Tweaking 16 16-09-08 05:29 PM
Fuelling upgrade? gazza SV Talk, Tuning & Tweaking 1 09-05-08 07:21 AM
Fuelling Problems curium SV Talk, Tuning & Tweaking 2 15-06-06 02:15 PM
