Old 14-07-11, 02:37 PM   #31
muzikill
muzikill's Avatar
Default Re: Removal of damper rod bolts
Any rules on tightening them back up? - doing it in situ? or out of the yoke? - hopefully they wont spin.
Old 15-07-11, 06:20 PM   #32
beabert
I can get them to 20nm by just holding the station with spanner at the brake mounts. I just use an impact driver to tweak them a bit more. They are supposed to be 30nm.
I must have lost so much oil, the bike feels solid now (im very light)
Old 17-07-12, 12:08 AM   #33
squirrel_hunter
squirrel_hunter's Avatar
Holy thread resurrection Batman!
Was doing a fork seal change at the weekend with Stretchie on a GSXF, but a similar fork design when it comes to the damper bolt. And so it was an ideal opportunity to try the impact gun method having only used the broom handle before. And I must report I was really impressed. The compressor and impact gun is an expense but when you use it on something like this it pays for itself. No effort required to get that bolt out. Didn't need to compress the fork and play with the gun just whack it on and the bolt was almost out before I knew it. It even did the bolt with no oil in the fork after a slight miscommunication between us.
Now the only thing remaining that can be a pain is reassembly. Is there an easier way to do this? To get the fork back together we did the broom handle to hold the internals as we torqued the bolt back up, not the easiest thing to do...
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 17-07-12, 06:54 AM   #34
barwel1992
We impacted it back up at work, if I remember rightly I don't thinkk we held it with any thing
Old 17-07-12, 08:28 AM   #35
Winder
Winder's Avatar
Buy a piece of threaded rod from B&Q and weld/glue a bolt on the bottom. This replicates the Suzuki fork assembly tool. If you look at the FORK ASSEMBLY connections on the link below it shows all the different heads that screw onto the T bar tool ( or B&Q threaded rod ). You can bodge something together to act like the genuine Suzuki tool for a lot of bikes by welding the right size nut to the end of your threaded rod.
If you look at the SV650 connector it is actually the shape of a sharpened broom handle! This is what was recommended to me but I have never done it. I bought a 12v impact wrench for £20 on eBay that connects to the lighter socket of a car or direct to battery terminals and my trusty sharpened broom handle.
http://www.alpha-sports.com/tools/suzuki_tools.htm
Old 21-07-12, 11:00 AM   #36
speedyandypandy
I'm with beabert, I've taken SV, GSX-R, ZX-R forks apart and serviced them, a Mayor WOOD, or a minor wooden stick works a charm, wood is good... Maybe I should start this post over again?
Last time I serviced a set of forks it was my mates zx6-r, after the internals where out from the first one using wood to help hold the internals, I did a small brainstorm and looked in my left-over-could-be-of-use-one-day metal box and found a pipe(old curtain pipe thingy) I hammered, filed and drilled to make myself a kwak fork tool
Old 22-07-12, 09:50 PM   #37
Whitty
Ouch! You animal!
They usually nip up easily by hand especially if dry from a full strip down. Don't forget new sealing washer if fitted on type of fork you are working on.
What damper is THIS? pilot SV Talk, Tuning & Tweaking 6 30-08-07 09:12 PM
Chain buffer removal requires swing arm removal :-( 2mths SV Talk, Tuning & Tweaking 1 09-07-07 09:19 AM
damper help me hera Photos 6 05-11-06 03:38 PM
Long bolts? Short bolts? andyaikido SV Talk, Tuning & Tweaking 6 25-01-06 04:53 PM
Steering damper Wiltshire7 SV Talk, Tuning & Tweaking 17 26-01-05 05:38 AM
