Old 01-09-05, 02:27 PM   #41
squirrel_hunter
squirrel_hunter's Avatar
If the problem is that there is not enough heat getting into the carb and the heaters on the bike aren't upto the task is it possible to get some sort of replacment heater or to piggy back whats already on there?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 01-09-05, 05:33 PM   #42
RandyO
Default Re: As per
Originally Posted by justmacsv650
Drop and extend the air intake ducts behind the radiator and get aviation fuel which is devoid of the same quantities of moisture as normal petrol
Resulting in warm air intake and moisture free fuel-------might work
warming the air up will not prevent carb icing, you have to warm the body of the carb
carb icing is basicly the same thing as choking the carb, ice builds up in the carb and reduces the amount of air that can pass.
the ice that builds up is from the humidity of the air and nothing to do with fuel
Old 01-09-05, 05:54 PM   #43
Here's the thing though, with SVs you can literally have 2 bikes parked side by side and ridden over the same journey in exactly the same circumstances, one suffers icing and the other doesn't. I've never suffered it at all despite doing a lot of riding in absolutely prefect icing conditions, which makes you wonder- why not? Why is it that one bike has problems while another powers on?
I don't have any actual solutions, natcherly Although one thing you see mentioned often is to move the sensor for the carb heaters- sometimes it ends up stuch somewhere warm and so fails to switch them on. Checking the wiring and connectors could be worth doing too- thpugh I tend to agree that they're pretty much irrelevant.
If I suffered it, I'd be looking at borrowing someone who doesn't suffer it's carbs... I know that logically that should be no difference, but something does, and logically it's got to be in the intake side of things.
Old 02-09-05, 11:19 AM   #44
alongwor
Am I right to assume this icing issue restricted only the carbed versions of the bike and the later fuel injected versions are fine?
Andy.
Old 02-09-05, 02:46 PM   #45
mysteryjimbo
Andy.
Yup.
Is this carb icing? captainsmelly SV Talk, Tuning & Tweaking 37 17-02-09 08:35 PM
Carb icing william t. SV Talk, Tuning & Tweaking 10 28-02-07 11:30 PM
Carb Icing Marshall SV Talk, Tuning & Tweaking 15 03-11-06 06:28 AM
Carb Icing fizzwheel SV Talk, Tuning & Tweaking 65 24-11-05 11:24 AM
Carb Icing: MrMessy Bikes - Talk & Issues 3 28-01-05 02:11 AM
