Old 02-02-10, 06:53 PM   #1
allantheboss
Default Battery charging and tank raiser questions.
What revs does the battery start charging from?
Optimal height to raise tank?
Old 02-02-10, 06:59 PM   #2
Alpinestarhero
Default Re: Random questions
Battery will start charging at tickover. As long as the voltage is above 12v (should be about 12.8 at tickover i think, maybe more) then the battery will be charging. At higher revs (above 4000) then the battery is charging more efficiently (receiving about 14 volts).
Dunno about raising the tank, I understand it just makes more noise. try a couple of washers under the bolts
Old 02-02-10, 07:03 PM   #3
allantheboss
OK.. I've been told it's better.
Thanks!
Old 02-02-10, 07:07 PM   #4
Alpinestarhero
Thanks!
Only if the bike is running silly rich...if you're in doubt if your bike is performning as it should, get it thouroughly serviced
Old 02-02-10, 07:08 PM   #5
allantheboss
Cool, no changes to be made then! Thanks!
Old 02-02-10, 07:21 PM   #6
squirrel_hunter
squirrel_hunter's Avatar
Raising the tank and removing the foam or heat shield will improve the air flow. What it adds performance wise is up for debate, but people far more knowledgeable than me have recommended and used it. Its not going to add 100bhp, but its not going to hurt it either.
Some details on the length (10mm) can be found here.
As for the charging: From my experience it won't charge properly until you get to about 5,500rpm. Stick your lights on at tick over, then rev the bike to 5,500rpm and watch them get brighter, a simple way to see your charging system in action.
And as a side were you riding through Old Town at about 5:30?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 02-02-10, 07:41 PM   #7
allantheboss
Yeah I was! <3 FATE <3
I will raise it. Need to find some screws and washers..
Old 02-02-10, 07:45 PM   #8
squirrel_hunter
Thought that was you. In which case do you need a hand removing the blue LED from the front of your bike?
Old 02-02-10, 07:54 PM   #9
allantheboss
WHAT! It's amazing! Go-faster lights!
Old 02-02-10, 07:58 PM   #10
squirrel_hunter
I'll sort it out for you. Don't worry. No charge.
charging the battery gico SV Talk, Tuning & Tweaking 3 02-04-08 05:39 PM
Charging the battery SV PILOT Bikes - Talk & Issues 7 31-03-08 05:05 PM
Charging/Battery: MrMessy Bikes - Talk & Issues 8 30-11-07 12:50 PM
charging battery hovis SV Talk, Tuning & Tweaking 6 24-09-06 02:59 PM
Is battery charging? Warthog SV Talk, Tuning & Tweaking 9 22-06-06 09:36 AM
