Ancillaries Post your own reviews, opinions and experiences on various other bits and bobs, such as rearsets, oil, engine bits.
Old 13-02-11, 04:55 PM   #1
muzikill
muzikill's Avatar
Default Probolt - bolt gauge
Got one of these coz im a lazy b, but still a great tool for checking bolt sizes!
pretty handy for having around and its a quick way to measure if you need to replace a bolt!
Old 13-02-11, 05:13 PM   #2
Geodude
Geodude's Avatar
Default Re: Probolt - bolt gauge
Ive got one of them lying around some where i forgot about. Quite useful it is, now where did i put it.
Old 13-02-11, 11:23 PM   #3
_Stretchie_
Large Member
_Stretchie_'s Avatar
Ok, place your bets, how long before someone asks "Where do you get one from?"
How to amuze an idiot:
Look right-> <-Look Left
Old 13-02-11, 11:31 PM   #4
squirrel_hunter
squirrel_hunter's Avatar
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 14-02-11, 09:46 AM   #5
Geodude
Geodude's Avatar
That would be here
Fairing bolt / Mirror bolt MiniMac Stuff Wanted 0 02-07-08 10:26 AM
how to get the sump plug/bolt or filter bolt out without murdering someone? Paul the 6th Bikes - Talk & Issues 11 31-05-08 10:49 AM
Help me build a spare bolt box; what are all the common bolt F16Falcon SV Talk, Tuning & Tweaking 10 07-05-07 08:42 AM
Temperature Gauge T0mm0 SV Talk, Tuning & Tweaking 10 27-01-07 06:11 PM
ProBolt Advice!!! Samurai SV Talk, Tuning & Tweaking 24 07-03-06 12:06 PM
