View Poll Results: Should I replace the gear?
Yes, get it done you tight wad. 17 94.44%
Nah. It'll be right. 1 5.56%
Voters: 18. You may not vote on this poll
Old 10-11-11, 01:18 AM   #1
TamSV
TamSV's Avatar
Default Would you replace this gear?
This is the RGV gearbox.
There's a slightly damaged tooth on the 6th Drive gear (the larger one in the pic) that was caused when the 6th and 2nd Driven gears decided to go their separate ways.
I'm spending a bit of cash replacing/upgrading the damaged driven gears, adding a taller first and replacing the worn selector forks.
The OCD part of me thinks I'm doing the work, I should spend the extra and replace the above too. The skint part of me thinks it'll be fine to leave as is and I'd have to be very unlucky to not get away with it.
Thoughts appreciated.
Old 10-11-11, 07:00 AM   #2
Default Re: Would you replace this gear?
Replace it, it'll pee you off if it goes in the future and you have to whip it all out again.
Old 10-11-11, 07:10 PM   #3
garynortheast
garynortheast's Avatar
Yep, replace it. It'll be noisy if you don't and you'll be constantly reminded of it.
Old 10-11-11, 07:14 PM   #4
littleoldman2
littleoldman2's Avatar
We all know your going to replace it, you cannot help yourself. I'd leave it, if its as good as the photo makes it appear, but you can't feel a photo.
Old 10-11-11, 07:29 PM   #5
squirrel_hunter
squirrel_hunter's Avatar
Replace it.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 10-11-11, 07:38 PM   #6
SpikeTM
Defo change it m8 as any missgearing when riding could just shear it off when being ridden .
Old 10-11-11, 10:04 PM   #7
I thought we decided that was minor al a Richie's K3 failure.
As your down to the component parts on the motor I'd do it as it'll annoy you if you dont
Old 10-11-11, 10:18 PM   #8
TamSV
TamSV's Avatar
lol. It's funny cause it's true.
Old 10-11-11, 10:21 PM   #9
Destruktor77
If I had an RGV I'd make sure it was perfect.
If you're doing a job you might as well do it properly and all at once. (I've learnt this with powervalves regarding 2-strokes )
Old 10-11-11, 10:32 PM   #10
Jayneflakes
Jayneflakes's Avatar
Wifey says that you should replace it all properly.
Jayne you're a Pussy Magnet
Replace broken gear lever? Rimer SV Talk, Tuning & Tweaking 14 19-10-12 10:21 PM
Is this going to replace the SV? TeddyBearKing SV Talk, Tuning & Tweaking 11 21-03-09 10:31 PM
Supermoto- Could it replace my sv? c_noble Bikes - Talk & Issues 3 10-01-08 11:51 PM
When to replace Gazza77 Tyres 7 27-06-06 05:07 PM
Repair or Replace Thaleshwar Tyres 2 02-03-06 05:54 PM
