Old 20-10-12, 03:07 PM   #1
squirrel_hunter
squirrel_hunter's Avatar
Default Bar Grip Replacement?
I need to replace the clutch lever assembly or perch if you will on my SV650S '99 model. To do this I need to slide it off of the bar, but the bar grip is in the way. Is there a tip or trick to help remove the grip if I wanted to reuse it? I have done this in the past but as I was replacing the grip I just cut the old one off, this time however I fancy reusing the grip and saving myself a couple of quids...
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 20-10-12, 03:20 PM   #2
Tomor
Tomor's Avatar
Shove a screwdriver down there to release all the glue and pull? May take some time though. Just a thought?
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 20-10-12, 04:37 PM   #3
Heefy
Default Re: Bar Grip Replacement
Yep. Get a screwdriver with a long thin shaft. Insert it slowly and gently between the rubber and the handlebar. Work it gently around the entire circumference of the grip. Spray a liberal amount of WD40 into the gap and twist and or peel the rubber off.
Good luck.
Old 20-10-12, 08:50 PM   #4
trudd
Push the wd40 tube under the grip as far as you can. Squirt wd40 and twist the grip. Repeat until the grip is off.
Old 20-10-12, 09:20 PM   #5
squirrel_hunter
Originally Posted by Heefy View Post
... a long thin shaft ... Insert it slowly and gently between the ... Work it gently around the entire circumference ... Spray a liberal amount ... into the gap ... and twist ...
Please, there is a U-rating on this site.
Tucano Urbano Neoprene Hand Grip Covers - R361 OR Symtec Heated Grip Kit? charlieferguson SV Talk, Tuning & Tweaking 0 13-10-09 08:08 PM
Grip in Wet? AndyL Bikes - Talk & Issues 33 28-10-08 11:33 PM
Grip Replacement MitchC SV Talk, Tuning & Tweaking 6 18-02-08 12:33 PM
Omg Omg GRIP freddifredfred Bikes - Talk & Issues 18 21-01-08 12:00 AM
Need more grip!!!! DarrenSV650S Idle Banter 34 09-12-06 06:52 PM
