Ok so im looking for some advice regarding my 1999 Curvy 650
Few nights ago i went to start my bike, turned ignition on as normal, went to start the bike, it started to turn the bike over then suddenly everything switched off and i now have no dashboard lights or anything when i turn the key. My first thought was ignition fuse - Checked and Replaced Next thought was dead battery, Tested old one, seemed fine but bought a replacement and fitted anyway to be safe, but still everything is dead Checked the connections and wiring accessible from battery compartment and everything again seems okay So now i have run out of any ideas, garages are closing for Christmas and money is a bit tight Any advice would be greatly recieved Graham |
Have you checked the main fuse? It's not in the fuse box, it's on the starter solenoid under the right hand seat panel.
Once you've located it, pinch the tangs, pull the greenish translucent cover off and you'll see two* green 30A fuses, one is the fuse, one is a spare, the spare one just sits in a plastic holder - no metal contacts. *Unless someone's nicked the spare of course - not unknown.
The other thing to check (once you've found the main fuse and sorted as reqd.) is whether you have any chafed wiring, there are a few well known places on a curvey.
1 - Check behind where the riders seat securing bolts go into the frame, take the black plastic triangles off first (both sides IIRC). The wiring harness runs just behind these bolts and they tend to be a touch too long and hit the harness. Consider shortening the bolts slightly or adding a washer. 2 - Check under the pillion seat in the cubby box at the left side of the bike towards the back, the wiring wraps round a frame bracket and can wear througfh on the edge. 3 - Check generally round the headstock where wiring can rub as you turn the bars.
#4 | |
Must say i feel rather stupid having forgotten completely that this fuse existed and having checked the others etc etc Problem solved Thanks for the help guys |
Okay guys, today i was riding my bike and my speedometer and rev counter were randomly shooting up and coming back down as i was riding and also whilst stationary, having stopped the bike after reaching my destination and then riding it home again a few hours later it was fine
Went to use my bike again tonight, put my bike into gear and once again the bike died, checked the 30A fuse and it has blown again Obviously tomorrow i will be replacing my fuse I feel there must be something more to my problems than just the fuse, especially as this will be my second fuse in a week and the speedometer/tach blipping i eperienced earlier today :S Any ideas what may be causing these? if they are related? |
I've had similar issues before...
First as Embee suggested check these wiring points for damage. Next check your battery connection is tight, a loose connection can cause the clocks to dance about. Next I would check the charging system. There are lots of guides on here on how to do that. I am suspecting that your reg rec has gone, is it the original Suzuki item or a replacement, what mileage has the bike done? Not the last reg rec I replaced, but the one before that was blowing the main fuse. New reg rec, new fuse and it was all sorted. And if it isn't that then at least you've checked your charging system which is one of the biggest weak points of the Curvy. |
Well after putting the new Battery on, i did all the various voltage test, ie, idle voltage, off voltage, revving at 5k all that sorta thing and everything was coming back as fine so i assumed all was good, wiring seems fine all the way through
Connections at battery are ok Mileage is just over 22k Is there a way to test the reg/rec? or is it just the voltage test across the battery at the different stages and scenarios? Last edited by Pionion; 27-12-12 at 12:50 AM. |
Check the main wiring loom where it runs past the rider seat bolt on the left. It's been known for the bolt to go through the insulation and cause a short.
Also check the the plug going to the starter solenoid....that's were the main fuse is. Unplug it and check for any signs of the melting insulation on the inside of plug and on the solenoid. That usually happens when the plug is not seated correctly. The result is arcing as it gets bounced about and eventually causes a short.
Nemo me impune lacessit. Last edited by 21QUEST; 27-12-12 at 12:51 AM. |
#9 | |
#10 |
Oops, missed embee's post...he'd already mentioned checking the left side of the riders seat.
I ought to quit speed reading. |
Dead Curvy - No electrical power. | Parisbun1 | SV Talk, Tuning & Tweaking | 16 | 29-04-13 06:53 PM |
Small electrical issue. | Kilted Ginger | SV Talk, Tuning & Tweaking | 4 | 05-03-12 12:10 PM |
Electrical problem - dead bike. | 18sv650 | SV Talk, Tuning & Tweaking | 6 | 04-02-12 04:45 PM |
Electrical Issue? | evo-orange | Bikes - Talk & Issues | 7 | 17-03-11 09:08 PM |
Dead Electrical | tekjunkie | Bikes - Talk & Issues | 4 | 29-03-07 04:37 PM |
