Old 03-05-13, 10:45 PM   #1
Fallout
Fallout's Avatar
Default Worn pads
Thought I'd put this up here for giggles. I bought the Tiger a few months back from a dealer and asked them to check the brakes as I'd be doing a load of miles. They assured me they had loads of life left in them. Thought nothing of it and did 4000 odd miles.
Service interval was due but couldn't get an appointment at a Triumph dealer for a month so decided to service it myself. Front pads had less than a mm left, but the rear pads were the star of the show. The rear calliper slider had jammed on one pin so had been wearing unevenly since new AFAIK. Disc is surprisingly fine considering, though discoloured where it was metal on metal!
Moral of the story for me is you just can't trust garages! I really want to buy a KTM from them in the future too, but now thinking there is no real benefit over buying privately. If you don't get piece of mind, then what is the point?
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 03-05-13, 11:00 PM   #2
squirrel_hunter
squirrel_hunter's Avatar
Default Re: Worn pads
Nice.
I've not gone that far. Did go down to the metal on a set of rear pads. Didn't bother me that much as it wasn't my bike. However Stretchie never lets me forget I did this to his Blackbird. He did tell me about them being low and I was supposed to do them before it got too low, but in my defence I don't use the rear brake. I also forgot that the Blackbird has linked brakes.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 03-05-13, 11:04 PM   #3
stuR
Its odd eh you either seem to hear alot of negligence or just selling you something you dont need yet. Wheres the honest guys? Although like anything you only usually hear the negative places and never about the good ones
Old 04-05-13, 05:59 AM   #4
NTECUK
NTECUK's Avatar
It might have been ok thickness wise when they looked at it.
All the salt on the roads has got into allot of things .
Shame you didn't pick it up when you did your once a week look over .
Old 04-05-13, 08:08 AM   #5
Fallout
Fallout's Avatar
I check everything more than once a week. You'd have to take the calliper off to be able to see it. You just can't get a good view with them on, so I took it on faith they'd last until the next scheduled service interval. It's the fault of the mechanic IMO if a bike has 4000 miles to the next service interval and pads have far fewer miles left on them. They need to make buyers aware of that, especially if I specifically asked them to check out the brakes. Oh wells.
Old 04-05-13, 09:13 AM   #6
Dicky Ticker
Some people are harder on brake pad wear than others, like tyre wear.
I am not defending the garage concerned but if it was 4000 miles on a set of tyres would you have changed them?
Appreciating that you asked for them to be checked before buying this is not good considering you seem to be a high mileage user.
I use a mirror on a telescopic arm, and a torch, for a quick check on my brakes between service intervals.
Regarding KTM,I considered a change myself but having read a few KTM forms and reports from individuals make sure you really want one for high mileage usage. Taking into consideration the spares availability, dealer service which you seem to have first hand knowledge of and depending on what model you are buying, where it is built and source of the build parts.
With Triumph I have always been able to get any parts 1 or 2 days after ordering them if they are not available from stock held in the dealers.
Old 04-05-13, 06:00 PM   #7
Fallout
Fallout's Avatar
The thing about the pads is if they had have checked them, they would've seen uneven wear and realised the calliper was jammed. Any unevenly worn pad needs changing and the problem rectified, imo. They can't have checked properly. I am not a big user of the rear brake either, so find it hard to believe I did all that wear myself. In any case, it's no big drama.
I don't think I could buy a KTM for high mileage. I always shop with my head and not my heart (boring I know), so if I do get one eventually it'll be as a toy.
Old 04-05-13, 06:17 PM   #8
I'm not sure you should blame them, brake pad life is very difficult to estimate.
Old 04-05-13, 06:54 PM   #9
Fallout
Fallout's Avatar
True, but a jammed calliper and a pad wearing unevenly should've been picked up when I asked them to check them out. I suspect margins are low on second hand bikes and a quick look over is all they get.
Old 04-05-13, 06:59 PM   #10
21QUEST
21QUEST's Avatar
Good that you caught it in time.
The truth I believe is, all the guff dealers(most) give about 1000 point check , full service etc etc is just, welll... guff
It's at the very least, very annoying
Nemo me impune lacessit.
Sprokets- Do these look worn out? andrewsmith Bikes - Talk & Issues 7 02-03-12 06:11 PM
part worn 180/55/17 husky03 Stuff Wanted 0 02-02-11 09:11 PM
worn front brake pads steveg SV Talk, Tuning & Tweaking 6 29-12-09 10:15 AM
worn carbs sv650nutter149 Bikes - Talk & Issues 1 24-10-09 08:24 AM
Could this be a worn clutch?? davros SV Talk, Tuning & Tweaking 7 10-02-05 04:19 PM
