Old 24-01-11, 07:47 PM   #11
squirrel_hunter
squirrel_hunter's Avatar
Default Re: Fitting Exhaust Gaskets!!!
Originally Posted by STRAMASHER View Post
My K3 is blowing at the gasket/clamp between the pipe and "stub". Audible phut-phut but not the kind of noise you get from a proper hole.
Is this an MOT fail? Or is it an "advisory" and at the testers descretion?
Every part of the MOT is at the testers discretion. I used to get an MOT done at a place where the only requirement was that the bike could drive into the workshop, stop, and had a horn that worked.
But the test states that it will fail if "Any part of the exhaust system missing or excessively deteriorated" or there is "a leak in the exhaust system which causes excessive noise to be emitted". My simple advice, if you think it might fail fix the problem.
And for reference the MOT Manual.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 25-01-11, 07:58 AM   #12
STRAMASHER
STRAMASHER's Avatar
Cheers SH. Will be having a word with my tester. Unfortunately there is no quick fix.
Old 25-01-11, 09:07 AM   #13
Ratty
Ratty's Avatar
My thou ran quite rough when the rear collector gasket failed. It's not a big job to do at all. Worst bit on the thou was you had to remove the side stand bracket to get the collector down, but this is probably ok on the 650. I got away with re-using the front header gasket. Rear collector gasket for mine was about £10.
Ratty
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Old 25-01-11, 11:48 PM   #14
barwel1992
ordered a new gasket for .....£2.70 lol inc P&P on ebay the front leaks a bit but i do like the lick of flames it puts out the back
Old 26-01-11, 12:31 PM   #15
Ratty
Ratty's Avatar
Header gasket or collector gasket ? If collector, where from because they fail regular on the thou ?
Ratty
Old 26-01-11, 05:30 PM   #16
barwel1992
Ratty
header sorry, my collector gasket was fine
Fitting new cylinder head cover gaskets flymo SV Talk, Tuning & Tweaking 12 05-10-10 08:48 AM
Exhaust gaskets mikerj SV Talk, Tuning & Tweaking 2 26-08-10 10:07 AM
SV1000s k4 Exhaust gaskets asteer17 SV Talk, Tuning & Tweaking 10 13-07-10 04:05 PM
SV1000 exhaust gaskets Mark_h SV Talk, Tuning & Tweaking 3 12-03-08 09:24 PM
Fitting exhaust gaskets andyaikido SV Talk, Tuning & Tweaking 4 19-02-06 05:29 PM
